Can the same tokens be staked with EarthNodes and e-SIMs?
Will we be able to stake the same tokens with ENOs and eSIMs to get all the benefits or do we have to choose only one staking method?
Hey @Buttforce, thanks for the question!
No, you can’t double-stake the same tokens across different programs. If you stake with EarthNodes, those tokens are dedicated to that program and can’t be used for eSIM staking at the same time. Each staking option rewards you differently, so you’ll need to choose the method that best aligns with your goals.
Staking with EarthNodes helps secure the network and gives you a say in governance—you earn WMTx rewards based on the EarthNode’s performance and uptime.
Premier staking is geared toward benefits tied directly to World Mobile services. As a US Mobile Plan customer, by staking WMTx, you unlock tiers that offer perks like cashback on your plan, VIP privileges, and premium benefits (Spotify, DragonPass etc).
Let me know if you have any more questions!
I was hoping there might be a way to get both sets of rewards from the same tokens, but I get why they’re kept separate. Appreciate the answer!
