What's the Difference Between worldmobile.com and worldmobile.io?
I’ve noticed there are two sites—worldmobile.com and worldmobile.io—and I’m a bit confused about what each one is for. Do they serve different purposes, or are they just different versions of the same thing? I’d really appreciate some clarification on which site I should visit to order the new SIM.
Hey @braznovt,
World Mobile, the decentralized network powered by AirNodes and Hex Guardians, runs on worldmobile.io—that’s the official site.
worldmobile.com is a totally different company that sells travel SIM cards. From what I’ve heard, they bought the domain and are just holding onto it, maybe hoping to make a deal with World Mobile down the line.
If you’re looking for the real, decentralized network that’s set to change the game, stick with worldmobile.io!
