International Roaming on World Mobile
Does World Mobile offer international roaming with their US Essential and Advanced plans? I haven’t seen any info on international data, so I’m assuming there isn’t any built in, but I’d like to confirm.
If that’s the case, how easy would it be to switch temporarily to the Global plan? Or are there plans for international add-ons on top of the Essential/Advanced plans in the future?
Hi @Blast3, welcome to The Club!
You’re right—the US Essential and Advanced plans don’t include built-in international roaming. For international travel, you’d need to switch over to the Global plan, which is currently data-only.
That said, if you’re part of the Premier Staking program, there’s a cool perk: starting from The Silver Tier, you get access to a Global Travel eSIM plan that includes 1GB of international data. And if you’re staking at higher tiers, that benefit increases (3GB on Gold, 5GB on Platinum, and 10GB on Black). So, if you’re already staking and climbing the tiers, you get international coverage.
Thanks for the welcome, @Coffee_WMTX!
Good to know about the Global plan and the staking perks for international data—that’s definitely something to keep in mind.
Is switching to the Global plan pretty straightforward? And would I keep my number? Also, any chance they’re planning to add international options for the Essential or Advanced plans down the line?
Appreciate the info!
