If I only stake from Cardano, do I need to bridge to WM Chain?
Quick question: if I’m just staking WMTX on Cardano, do I ever need to bridge over to the World Mobile Chain?
Hey @mustik, welcome to The Club!
Nope, if you’re only planning to stake from Cardano, there’s no need to bridge to WM Chain. Core Staking will be available natively on Cardano through the updated Vault, so you can stake your WMTX right from there.
Bridging only comes into play if you want to interact with the EVM side or eventually stake from WM Chain itself. But if you’re happy on Cardano, you’re good to go as-is.
Yep, same here. I’ve got little trust in ETH. I’ll be staking from Cardano too to keep things simple, secure, and on-chain where I’m comfortable. Unless you’re planning to mess with dApps or tools on the EVM side, there’s honestly no reason to move over.
I’m really glad they kept native staking on Cardano. Would’ve been a huge miss if they forced everyone to bridge.
