I’ve been a Cardano holder for a long time, but I’m new to navigating cross-chain transfers. I’m trying to figure out how to move WMTX between Cardano, Ethereum, and Base. With WMTX already available on these networks, what’s the simplest way to bridge it?
Hi @yopebet , welcome to the community!
Bridging $WMTx is easy, here’s how:
1. Bridging Between Cardano and Ethereum
For transfers between Cardano and Ethereum, the SingularityNET Bridge is your best option. Follow these steps:
- Visit SingularityNET Bridge.
- Connect your wallet:
- For Cardano, use Nami, Eternl, Gero Wallet, or Flint.
- For Ethereum, use MetaMask.
- Ensure your wallet is set to the correct network (Cardano or Ethereum).
- Select $WMTx as the token to transfer.
- Specify the source and destination blockchains (e.g., Cardano → Ethereum).
- Enter the amount to transfer and check it’s within the limits.
- Review the details, including fees, and confirm the transaction.
- Approve the transaction in your wallet and wait for it to process (usually a few minutes).
- Verify the transfer in your destination wallet.
2. Bridging Between Ethereum, Base, and BNB
For moves involving Base or BNB, Houdini Swap is great because it supports multiple chains:
Here’s how to use it:
- Go to Houdini Swap.
- Select your transaction mode:
- Standard Mode for speed.
- Private Mode for privacy (takes longer).
- Choose $WMTx as the “From” token and your desired network (e.g., Base, BNB) as the “To” token.
- Enter the amount to swap and your receiving wallet address.
- Click “Find the best route” to optimize costs.
- Review the details and confirm.
- Approve the transaction in your wallet or send the specified amount manually.
- Track your progress on Houdini Swap—most swaps complete in minutes!
Tips for a Smooth Experience
- Use the Right Wallet: MetaMask for Ethereum/Base, Eternl for Cardano.
- Be Ready for Gas Fees: Have enough ETH, ADA, or BNB for transaction costs.
- Double-Check Details: Verify addresses and amounts before confirming.
- Be Patient: Network traffic can cause delays, so give it time.
Stay Secure
Always use official platforms and verify URLs to avoid phishing scams. If it’s your first time, start with a small test transaction to make sure everything works smoothly.
If you have any questions, feel free to ask—everyone here is happy to help!
Thank you! I used the Bridge from SingularityNET and it all went fine. Lots of annoying scammers on discord, be very careful.
Glad to hear all went well
