How long does wallet verification take after sending the ADA?
I just sent the required ADA amount for wallet verification.. how long does it usually take before the system confirms it and my balance appears? Thanks!
Hi @Dissss, it usually takes anywhere from about 5 minutes up to an hour for the verification to clear and your balance to show. Most users see it pop in under 10 minutes, but if the Cardano network is busy it can stretch closer to 60 minutes. If it’s been over an hour, try clearing your cache or logging out and back in - otherwise drop a message to World Mobile support and they can double-check for you.
