How long does it take for WMTx to appear in the Vault after wallet verification?
Hey folks,
I just verified my Cardano wallet in the new Vault by sending the requested ADA amount to myself. It says the wallet is active now, but my WMTx balance still shows as 0.
Does it usually take a few minutes to update, or should it appear right away?
Just wondering if I should wait, refresh, or if something might’ve gone wrong.
Thanks in advance! :folded_hands:
Hey Roseflag,
That sounds normal. After verifying your wallet, it can take a few minutes for the Vault to pull your WMTx balance. Sometimes a quick refresh helps, and in a few cases a hard refresh (Ctrl+F5) does the trick.
If your Vault says “active,” then the verification went through fine. Just give it a bit and check back shortly.
One thing to keep in mind: if your WMTx is split across multiple addresses within the wallet, the Vault might not detect all of it right away. You can send the full balance to a single receive address within your wallet if it still doesn’t show after a little while.
Let us know how it goes. It usually sorts itself out pretty quickly!
