How does Core Staking APY work, and does Premier Staking stack on top?
Hey all, just trying to wrap my head around how staking works in the World Mobile ecosystem.
From what I understand, Core Staking offers around 5% APY, depending on network conditions. How much will this fluctuate?
Also, I noticed Premier Staking is unlocked through one of the mobile plans. So here’s the part I’m unsure about: does Premier Staking add on to the Core staking rewards? Like, if Core gives ~5%, do you get that plus Premier perks (cashback and bonuses)? Or is Premier Staking a totally separate incentive model?
Just trying to figure out how it all fits together before I commit more WMTx.
Hey @Dissss, welcome!
You’ve got it mostly right. Core Staking offers around 5% APY. That rate can fluctuate a bit based on things like network usage, how much is staked overall, and a few other variables but it should stay close to that 5% mark.
Premier Staking doesn’t stack on top of Core, it’s a separate track. It’s tied to the mobile plans and comes with perks like WMTx cashback, but it replaces Core rewards rather than adding to them. You can do both, but you’d need to use two separate wallets: one for Premier, one for Core — as the same tokens can’t be staked in both programs at once.
So really it comes down to which setup fits your use of WMTx best.
Appreciate the reply. I was kind of hoping the Premier rewards stacked on top of Core, but it makes sense that they’re two separate setups. I’ll probably split it, keep most WMTx in Core for the APY and use a different wallet for Premier to get the first cashback tier perk through the plan.
Thanks for walking it through.
