Guide: Setup your EarthNode Grafana Dashboards 📊
Effective monitoring ensures your EarthNode runs smoothly and efficiently. This guide walks you through setting up a Grafana dashboard to track key metrics, optimize performance, and receive alerts when issues arise.
Step 1: Install and Connect Grafana
  1. Install Grafana on your server or local machine.
  2. Connect it to Prometheus to collect real-time EarthNode data.
Step 2: Import or Create a Dashboard
  1. Use an existing EarthNode Grafana dashboard or create a custom one.
  2. Import a template and adjust it to track essential metrics.
Step 3: Customize Your Monitoring
  • Track CPU, RAM, and disk usage.
  • Monitor network performance and uptime.
  • Set up alerts for performance issues.
Step 4: Share Your Dashboard
Help the EarthNode community by sharing your setup. Provide:
  • Configuration files or source code
  • Screenshots of your dashboard
  • A summary of tracked metrics
A well-optimized dashboard improves monitoring and keeps your EarthNode - and the World Mobile Chain - running at peak performance.
