Guide: How to Sign Up for a World Mobile Phone Plan (USA)
Looking for a mobile plan that protects your privacy, puts you in control of your data, and rewards you for staying connected?
World Mobile is a first-of-its-kind, community-powered network designed for security, transparency, and fair pricing. Enjoy reliable connectivity at competitive rates while earning rewards for being part of the network.
This guide will walk you through the simple steps to sign up and activate your World Mobile cell phone plan.
Step 1: Choose a Phone Plan
Compare available World Mobile phone plans and select the one that best fits your needs.
← Explore the Phone Plans
Step 2: Sign Up and Create an Account
  1. Visit the World Mobile Phone Plan Page
  2. Choose your plan.
  3. Provide your details.
  4. Enter payment information.
  5. Confirm your subscription.
Important Note 1:
The World Mobile eSIM can only be installed once. Do not remove the eSIM from your phone after installation. If it is accidentally removed or you need to switch devices, please contact World Mobile support.
Important Note 2:
To use the World Mobile eSIM, your device must be carrier-unlocked and eSIM-compatible.
Important Note 3:
Activation is available within the U.S. only. If you are outside the U.S., you must wait until you are in the country to activate your eSIM.
Step 3: Receive and Activate Your eSIM
  • Follow the on-screen instructions to activate your eSIM. Depending on your device, you may need to scan a QR code or enter activation details manually.
Step 4: Start Using Your World Mobile Plan
  • Configure APN settings if necessary.
  • Start enjoying decentralized mobile connectivity.
Need help? Ask The Club for support.
Frequently Asked Questions
Do I need to be in person to install an eSIM?
No! You can install and activate the World Mobile eSIM from anywhere within the U.S. without needing to visit a store or other physical location. You may even do it from the comfort of your own home.
When & where can I install my eSIM?
If you’re within the United States, you may install and activate your eSIM once you’ve received your eSIM plan. If you’re moving to the U.S. or just visiting, you must install and activate it once you are within the country to avoid activation issues.
How can I get an eSIM?
After signing up for service and completing your purchase, you will receive an email with activation instructions.
How long can I use an eSIM?
Your eSIM remains active as long as your subscription is active and the eSIM is not uninstalled.
Is there an activation fee?
No, World Mobile does not charge any enrollment or activation fees.
Are your plans on a contract?
No, World Mobile’s mobile plans are contract-free.
Are your plans truly unlimited?
Yes! Once you’ve reached your allocated amount of high-speed data during the billing cycle, a throttle is introduced until the new billing cycle begins.
