Guide: How to Find Your IMEI on Android
The IMEI (International Mobile Equipment Identity) is a unique number assigned to your Android device. It is used for unlocking, reporting a lost or stolen phone, troubleshooting with World Mobile, and checking device compatibility. Here’s how to find it:
Find the IMEI in settings
If your phone is working, this is the easiest way to check your IMEI.
  1. Open settings
  2. Tap about phone
  3. Scroll down to IMEI
If your phone has dual SIM, you may see two IMEI numbers, one for each SIM slot.
Find the IMEI using a dial code
Even if your screen is locked, you can retrieve the IMEI using this method.
  1. Open the phone app
  2. Dial *#06# and press call
  3. The IMEI number(s) will appear on the screen
Find the IMEI on the device
If your phone won’t turn on, you may still be able to locate the IMEI physically.
  • Many Android phones have the IMEI printed on the SIM tray
  • On some older models, it may be printed on the back of the phone
  • If your phone has a removable battery, check inside the battery compartment
Find the IMEI through your Google account
If your phone is lost, you can check the IMEI remotely through Google.
  1. Go to Google’s Find My Device
  2. Sign in with your Google account
  3. Select your device from the list
  4. The IMEI may be displayed in the device details
This method is useful if you no longer have your phone but need the IMEI for unlocking or reporting it stolen.
Ask for help if you have any trouble finding it!
