Guide: How to Check if Your iPhone Supports eSIM
eSIM (Embedded SIM) is a digital SIM technology that allows you to activate a mobile plan without needing a physical SIM card. It provides greater flexibility, enabling users to switch carriers, add multiple plans, and travel internationally without swapping SIM cards.
If you are considering using eSIM with World Mobile or any other carrier, follow this guide to check whether your iPhone supports eSIM.
Method 1: Check in iPhone Settings
The easiest and fastest way to determine if your iPhone supports eSIM is through the settings menu.
Steps to Check eSIM Compatibility in Settings
  1. Open Settings on your iPhone.
  2. Tap Cellular (or Mobile Data, depending on your region).
  3. Look for an option labeled Add eSIM or Add Cellular Plan.
  4. If you see this option, your iPhone supports eSIM.
If this option is missing, your iPhone does not support eSIM, or the feature may be disabled by your carrier.
Method 2: Check Your iPhone Model
Apple has been integrating eSIM technology into iPhones since 2018. If your iPhone is from this period or later, there’s a strong chance it supports eSIM.
iPhones That Support eSIM
  • iPhone 15 series
  • iPhone 14 series (U.S. models are eSIM-only, with no physical SIM slot)
  • iPhone 13 series
  • iPhone 12 series
  • iPhone 11 series
  • iPhone XS, iPhone XS Max, and iPhone XR
  • iPhone SE (2nd generation) and later
If your iPhone is older than iPhone XS (2018), it does not support eSIM.
Important Notes
  • Some carrier-locked iPhones may have eSIM disabled. If your device was purchased through a carrier, ensure it is unlocked to access eSIM functionality.
FAQ
Can my iPhone have both a physical SIM and an eSIM?
Yes, most eSIM-compatible iPhones (except U.S. iPhone 14 models and newer) support Dual SIM, allowing you to use both a physical SIM and an eSIM simultaneously. This is useful for separating work and personal numbers or managing different carriers.
What should I do if I don’t see the “Add eSIM” option?
  • Ensure your iPhone is unlocked and supports eSIM.
  • Check for software updates under Settings > General > Software Update.
By verifying eSIM compatibility through settings or by checking your iPhone model, you can determine whether your device is ready for an eSIM-powered mobile experience with World Mobile or another provider.
