Do ENNFTs get counted automatically when staking?
I have an ENNFT in the same wallet I’m using for Cardano staking. Do I need to do anything to make sure it gets counted, or is it automatic? Thanks!
Hey fellow ENO!
You’re good - as long as the ENNFT is in the same wallet you’re using for Cardano staking, it’s counted automatically.
The Vault reads the contents of your wallet and includes the ENNFT boost without you needing to do anything extra. Each ENNFT adds 100,000 WMTx to your staking weight, and it applies for the full staking period as long as the NFT stays in your wallet.
If you check your Vault after linking the wallet, you should see the increased staking balance reflected there. Just make sure not to move the ENNFT out of the wallet during an active staking cycle, or you’ll lose the EN boost for that period.
No action needed, you’re already set. Let us know if the balance doesn’t show up properly and we can help troubleshoot.
