Do different Cardano wallets affect staking in the Vault?
I’m setting up the Vault and trying to decide which wallet to use. Does it matter if I use Eternl, Lace, Nami, or something else? Does it affect rewards or staking performance?
Hi @napjip,
All of the supported Cardano wallets (like Eternl, Lace, Nami, and Typhon…) will work fine with the Vault. Your choice of wallet won’t affect your staking performance or rewards, as long as it’s compatible and properly connected.
What does matter is using a self-custodial wallet (which all of those are), and making sure your WMTx is held in the wallet you connect to the Vault.
It really comes down to personal preference. Some people like Eternl for its advanced features, while others find Lace easier to use. Nami and Typhon work well too.
Only one to avoid at this point is Yoroi, since it’s no longer well-supported.
So you’re safe with any of the modern wallets, just go with the one you’re most comfortable using.
