Cheapest phone that will work with world mobile?
I’m looking for the most affordable compatible phone to use with World Mobile? I need a low-cost device that works with World Mobile and ideally syncs with Google Messages. Any recommendations for budget-friendly options?
Hello @Raingrab,
If you’re looking for the cheapest phone that works with World Mobile and supports Google Messages, your best bets are going to be on the Android side. Based on the current list of compatible devices, the Samsung Galaxy A35 5G and Galaxy A54 5G are two of the most affordable options. Both are mid-range phones that offer solid performance, 5G support, and full compatibility with Google services like Messages.
Out of those, the Galaxy A35 5G is the more budget-friendly one. You can usually find it unlocked for a good price, and it’ll work fine with World Mobile’s eSIM setup.
If you’re into Pixel devices, the Pixel 8a would likely be the cheapest compatible Pixel, but right now the Pixel 8 is the lowest-end one on the list, and it’s a bit more expensive than the A35.
You can double-check compatibility on World Mobile’s site using the “Is your phone compatible?” button just to be safe.
