I’ve got WMTx on both Cardano and Base and was wondering if it’s possible to stake on both chains at the same time using different wallets?
Hey @inesis,
Yes, you can stake WMTx on both Cardano and Base at the same time using different wallets and vaults. Each chain handles staking separately, so there’s no issue staking on both as long as the tokens are on the correct network.
Totally fine to do, and a great way to take part in both systems.
