I’m trying to stake my WMTx on Base using MetaMask with my Ledger, but the balance is showing as 0 in the Vault. Is this just me or has anyone else run into the same thing?
Hey @Gladir,
That setup should work, but there are a couple things worth checking.
First, make sure your WMTx is actually on Base, not Ethereum. The Vault only reads WMTx that’s been bridged to Base. If it’s still on Ethereum, you’ll need to bridge it over first using this site:
https://worldmobile.net/wmtx/bridge
If your tokens are already on Base, double-check that MetaMask is connected to the right account, especially if you have multiple Ledger addresses in your MetaMask wallet. It’s easy to be logged into a different one than the one holding your WMTx.
Once everything’s connected properly, you should see your balance in the Vault. If not, try refreshing the page or reconnecting the wallet. Sometimes MetaMask with Ledger just needs a reset.
Let us know if none of that helps and we can troubleshoot further.
