Can I set up the Vault and stake from a mobile device?
Is it possible to create or access a Vault and stake WMTx using a mobile device, or do you need to use a desktop for that?
Hey @mustik,
You can set up and access the Vault from a mobile device, but in practice, it’s not always smooth. Some users have done it successfully, but there are often small issues like trouble copying the seed phrase or password, or the browser refreshing mid-process.
If mobile is your only option, you can give it a go, just be patient with it. But if you have access to a desktop or laptop, that’s definitely the easier and more stable way to complete the initial setup, especially when creating the Vault and verifying your wallet.
Once everything is set up, checking in or monitoring your stake works just fine on mobile.
