When setting up my new Vault, I used the same Cardano wallet address that I had connected to the old Vault before staking was paused.
It seemed to recognize the address, but still asked me to verify it by sending ADA.
Is that normal? Just want to make sure there’s no issue with using the same wallet again.
Yes, that’s normal. Even if you’re using the same Cardano wallet as before, the new Vault treats it as a fresh setup. That’s why it still asks you to verify the address by sending a small ADA transaction to yourself.
It’s recommended to use the same email and wallet address you had in your old Vault. That’s what links your new Vault to any potential legacy rewards once they become claimable in a future update.
