I think I messed something up when setting up my Vault. Is it possible to delete it and start again with the same wallet or a different email?
Hey @cuppatea,
Yes, you can definitely start over if something didn’t go right.
If the Vault isn’t working as expected or got stuck during setup, try clearing your browser cache and cookies, or use the “Delete Vault” option if it shows. That’ll let you begin fresh.
You can create a new Vault using the same wallet and email if you’re trying to recover rewards from the old system. But if you just want a clean setup and don’t need to link old rewards, you can use a different email or wallet too.
The system’s flexible that way, just make sure to securely save your new seed phrase and .json backup file when you set it up again.
Let us know if you need help along the way.
