Can I add World Mobile as a secondary esim and keep my current carrier?
Wondering if I can use World Mobile as a secondary eSIM while keeping my current carrier active. Checked the website but couldn’t find a clear answer.
Welcome @Macon!
Yes, you can use World Mobile as a secondary eSIM while keeping your current carrier. Recent iPhones let you run multiple eSIMs or an eSIM alongside a physical SIM, so you should be able to set it up without issues. You can choose which SIM handles calls, texts, and data in your settings.
The only thing to check is if your iPhone model supports eSIMs, since older models don’t. If you let us know which iPhone you have, someone here might be able to confirm.
