ADA → ETH Bridge Transaction Stuck in Processing
I’m having an issue with my ADA-to-ETH bridge transaction on SingularityNET—it’s been stuck on “processing” with that spinning wheel for a while now, and I’m starting to get a bit anxious. Has anyone else run into this before? Any tips on what I should do—just wait it out, or try something different?
Hey @SuperRamen,
It sounds like you’re running into delays with the Singularity Bridge—it’s known to be slow (and a bit pricey) at the moment. Since the bridge is run by Singularity (and not by World Mobile), the best step is to contact them directly via their support link. In my experience, they got back to me within a few hours. I’m also looking forward to the full Houdini integration, which should improve the experience and allow more swaps.
Hang in there!
